LabVIEW at 20!
I started looking into LabVIEW when it was first introduced on the Windows platform. I was working for Polaroid and thought it might have potential as a replacement for the text-based programs that were used on our growing line of test equipment. It slowly became the sole programming language for the entire world-wide camera testing lineup. The first program I wrote took many months...the last only a few days.
Sadly, all of the test equipment is being moth-balled (basically trashed)  as Polaroid is being dismantled and destroyed by the current owner.
Message 101 of 176
(3,071 Views)
OK, I'm in...  LabView 2, 1990 or so.
Still have the LabView 2 and LabView 2 Advanced training mauals complete with some ancient blue non "HD" disks. We were working on Inertial Measurement Unit (IMU's) test and evaluation software. Two of the completed units flew to the moon on Clementine!
Message 102 of 176
(3,029 Views)
I started in the early 90's using a MAC, an NI TI-DSP based ISA board and an SCXI chassis.  The system worked great for real-time closed loop control.  I've been using LabVIEW NI stuff ever since.  Works great, most of the time.
Steve Hall
stephen.hall@parker.com
Message 103 of 176
(2,983 Views)
I've just started a mass compile from Version 8 to version 8.01. From the looks of it it will be another twenty years before I can do any freakin work Smiley Sad
Message 104 of 176
(2,959 Views)
Maybe you can cut ot down to only a few years by following the tips here:
http://forums.ni.com/ni/board/message?board.id=170&message.id=172705#M172705
Message Edited by altenbach on 06-03-2006 09:35 AM
Message 105 of 176
(2,949 Views)
Hello All,
How can I arrenge the first LabView for Windows?
I only work in Labview since 5.1 and I would like to try, just for fun.
Message 106 of 176
(2,938 Views)
@Carmo wrote:
Hello All,
YES PLEASE !!!
I would also love to have a (30d) trial version , even if I have to reinstall windows 3.1 (or whatever)
How about a VM- setup ? Maybe Apple spend the old OS and we all can try out ?
Message Edited by Henrik Volkers on 06-07-2006 10:24 AM
Greetings from Germany
Henrik
LV since v3.1
Message 107 of 176
(2,894 Views)
I believe I still have LV 5.1.
Since I'm currently at 6.1 this is hardly surprising......
I think 5.1 works on Windows 98 anyway, so at least a Win3.1 installation is not required (Although it is the method of choice for 64% of all IT masochists).
Henrik, I think you meant "donate" when you wrote "spend"?
I do remember programming without an undo function.  Man, that way you could REALLY learn to concentrate.  Was that 5.1 or earlier?
Shane.
Message Edited by shoneill on 06-07-2006 11:25 AM
Using LV 6.1 and 8.2.1 on W2k (SP4) and WXP (SP2)
Message 108 of 176
(2,889 Views)
Shane,
I have 5.1 and even 4.1 somewhere on old backups (and W98 still running on a PC)  and started with LV3.1 (definitely without undo, and I still automatically press Ctrl-S after every bigger modification and always before I run a vi)
I would love to try out the really first (MAC) version.  If not a VM snapshot maybe NI can bring up a Web version. Why not with an old MAC, a webcam and some sort of mouse/keyboard interface?.
It's like turning on an old tube-radio and listening to the humm.  (Actually I used a tube radio to debug my first steps in Sinclair ZX81 assembler debugging Smiley Very Happy  )
And yes I had 'donate' in mind. Thank you for the correction, still learning english by *dboing*.
Henrik
LV since v3.1
Message 109 of 176
(2,876 Views)
Henrik wrote;
(Actually I used a tube radio to debug my first steps in Sinclair ZX81 assembler debugging   )
OK, I can't let that one go without a follow-up. I once saw Spock do that in "The City on the Edge of Forever" (?) but I could not ask follow-up Q's about what he was really doing.
So how did the tube radio help with your debugging?
Curious,
Ben
Message 110 of 176
(2,871 Views)
