LabVIEW NXG 1.0 installation error. "Check Internet connection and try again"
Hi All,
I tried to install "LabVIEW NXG Suite Free Evaluation" with no success. The installation file first installed .net, then NI Package Manager. I chose "LabVIW NXG" and "NI-DAQmx" and after clicking on next the error
Invalid checksum for package <path>\ni-labview-ng-1.0-released.nipkg
Please check your  internet connection and try again.
There is no problem with the internet connection at all. Please check the images in the attachment.
Message 1 of 9
(11,861 Views)
I have exactly the same problem. I am attempting to install onto Virtual Machine (VM) running Windows 10. Deleting the .nipkg files, to force a new download, didn't fix the problem. The downloaded package files are all 2kB in size.
This installation was downloaded from the NI web site: http://www.ni.com/gate/gb/GB_EVALLVNXG/US
David C
Message 2 of 9
(11,804 Views)
I had the same issue. But there is a workaround that worked for me.
What you need to do is to:
1. Close NI Package Manager
2. Go to C:\ProgramData\National Instruments\NI Package Manager\Downloads\
3. Double-click on ni-labview-ng-1.0-released.nipkg and install the package
4. Double-click on ni-labview-ng-1.0-released-critical.nipkg and install the package
5. Restart NI Package Manager and try installing LabVIEW NXT again
Hope this can help you!
Nikita.
Nikita Prorekhin
CLA
Message 3 of 9
(11,767 Views)
Accepted by JeffreyH
Thanks, Nikita. That worked. Pretty sure I ran the ni-labview-ng-1.0-released-critical.nipkg and the installation failed. I retrieved ni-labview-ng-1.0-released.nipkg from the trash and re-ran it. That seemed to fix the problem when I followed your steps.
David.
David C
Message 4 of 9
(11,752 Views)
The install errors should be resolved now for those who haven't used the workaround. There was a file that wasn't publishing correctly after it was updated. Thanks for the report!
Message 5 of 9
(11,686 Views)
I tried what you said but it says "Package is already installed".
After that , I restarted Package Manager but different error pops up "NI Certificated Installer".
See attachments.
Message 6 of 9
(11,683 Views)
Accepted by nik35324
One other potential source for the error is a IT policy too be a bit aggressive with "Protection" settings.  I was able to change the add "https://ni.com" to the trusted sites and resolve my issue
"Should be" isn't "Is" -Jay
Message 7 of 9
(11,551 Views)
Message 8 of 9
(11,382 Views)
This can also be the cause for this:
-LESS SPACE AVAILABLE
Message 9 of 9
(5,897 Views)
