Sub Panel not working in Exe file
hi friends
I have an project which contain more no front panel
So i used an sub panels for each vi
While executing through Source code it is working fine
When i tried to make an exe file it is not working kindly guide ne to solve this issue
Thanks in advance
Message 1 of 18
(3,607 Views)
Hi kps,
The problem is in your code: in my executables subPanels work as expected, showing all kind of VIs…
As you forgot to attach any code you need to debug on your own!
What is "not working"? You know this "not working" is no error message by LabVIEW!?
Message 2 of 18
(3,603 Views)
In this above image one is exe execution and another one is source code execution in source code execution it is working fine but in exe it is not running,
Message 3 of 18
(3,591 Views)
Hi kps,
What exactly is included in your subPanel(s)? What is "not running"?
Again you gave no error description which we can analyze: "not running" is also no error message by LabVIEW!
Again you failed in attaching source code…
Message 4 of 18
(3,581 Views)
Message 5 of 18
(3,577 Views)
hi sir
i mean the sub panel vi is not executing
Message 6 of 18
(3,573 Views)
More info would be useful.
My bet is you will need to "always include" those subpanel VIs in your build spec. (Since the VIs or static references are not included on the block diagram they may not be automatically included in the build).
0xDEAD
Message 7 of 18
(3,571 Views)
there is no error also
Message 8 of 18
(3,568 Views)
i include those sub vi also while build an exe
Message 9 of 18
(3,567 Views)
Hi kps,
Using the correct path?
Are you sure you get no error from LabVIEW? Really sure? The error handling in that loop looks bogus to me…
Still no code attached. All you show are images…
Message 10 of 18
(3,540 Views)
