LabVIEW IPE Structure Unbundle/Bundle Type Propagation Error/Crash
SRN 03988339
LabVIEW 2025 Q3 f2
LabVIEW crashes when wiring a bundled cluster of elements to an IPE structure's unbundle/bundle nodes when (a) there is wire internally connecting the unbundle to the bundle, (b) the outer terminal of the IPE structure's unbundle is unwired, and (c) a wire from a bundle with a cluster of elements is connected to the outer terminal of the IPE structure's unbundle.
The work-around (lesson) is: do not pre-wire the internal unbundle/bundle until after you wire the external unbundle input to the IPE structure.
See attached IPE_Crash_Reproducer.zip file for Example VI (configured as shown, below, in Before the Crash)
Before the Crash
Triggering the Crash
(1,060 Views)
Reproduced in:
LV24.3.2f2, 64-bit.
LV24.1.1f1, 32-bit.
LV18 64-bit.
So probably a problem in every released version...
(948 Views)
Reproduced in 2023 Q3 64-bit, 23.3.6f6. Made the diagram from scratch, so your VI isn't unusually corrupted somehow.
(939 Views)
I also made all the VIs from scratch.
I used an error cluster, the items have labels and so does the cluster, so that saves a few clicks. Works well (as in: it still crashes).
(933 Views)
That's a very specific workflow. Did you find it by accident?
That was the dumbest question I have asked so far. I guess if it was part of your workflow you would've seen it years ago.
Bill
CLD
(Mid-Level minion.)
(910 Views)
I happened upon it while trying to insert an IPE Structure directly inline with an existing cluster wire inside a state machine. This has a lot of repetitive steps so my mind is always playing with how to reduce steps and maybe automate them, plus curious about how the different parts behave.
once I experienced the crash, I whittled things down to the simplest way to reproduce it, to make it very easy to verify it’s really a bug (by support engineers) and also easy to start working on a fix (by R&D).
That’s why it looks specific: because all that’s left is (hopefully) the specific causes of the bug.
M
y guess is that it’s some corner case having to do with the order of operations in edit-time type propagation and the smartness around how untyped named bundlers bind to elements when a datatype is first assigned. There’s a lot of smarts and magic behind the type propagation in LabVIEW.
cheers
(868 Views)
Accepted by Jim_Kring
(861 Views)
