LabVIEW 6.0.2 crashes when buildin vi that calls DLLs
During building a vi that calls a DLL (generated by cygwin) LabVIEW 6.0.2 chashes everytime. I'm getting angry ! I tried with labVIEW 5.1 and it goes easily. Does anyone had any solution for that ?
(2,409 Views)
If I recall correctlly, a DLL in LV5 defaults to "reentrant" execution. In
LV6, the dll defaults to "Run in UI Thread" execution. So in LV6, you can
try to change this, it might fix the problem.
Wiebe.
"RA Eletro" wrote in message
news:50650000000800000074530000-1027480788000@exchange.ni.com...
(2,409 Views)
Hi RA Electro,
Check your calling convention to ensure it matches what the DLL expects. The wrong calling convention will cause crashes @ compile time.
I suggest you get it working in a small VI all by itself. I have had to coplete blow away a call and start over when I saved the worng way.
Check your convention.
Ben
(2,409 Views)
The crashes happen without compiling. With version 5.1 it seems more stable.
After restarting millions times, I can have the vi working.
(2,409 Views)
FYI
In LabVIEW teh VI is re-compiled everytime you make a change. Thats what gives the broken wires and the like.
Ben
(2,409 Views)
RA Electro,
I assume that you also have the LabVIEW 6.0.2 Run-Time Engine installed. You can get errors like this if you try running your application off of the LabVIEW 6.0 Run-Time Engine.
Randy Hoskin
Applications Engineer
http://www.ni.com/ask
(2,409 Views)
