Just openning LabVIEW & causing 99% CPU usuage
Hi folks,
I just opened LabVIEW 8.2.1 and after it finishes its initalization, while on the Getting Started screen LabVIEW is using 99% of CPU.
I tried restarting & repairing the installation but to no avail. Anybody encountered this problem?
Thanks in Advance!
Message 1 of 21
(4,803 Views)
Is it the LabVIEW process itself that's causing the CPU utilization, or is it one of the services that gets installed with LabVIEW?
Message 2 of 21
(4,786 Views)
Good question.
If it ends being eaten up by NIPAL.... and you have LV 6.1 on that machine then you may be seeing what I saw and forced me to remove the LV 6.1 install.
Ben
Message 3 of 21
(4,781 Views)
labVexpert2b wrote:
...while on the Getting Started screen LabVIEW is using 99% of CPU.
Does everything still work?
Is the 99% CPU only for some time duration or forever? How long did you wait?
What happens if you open a VI directly? Does the CPU drop?
What happens if you close the last open VI to go to the welcome screen? Back to 99% CPU?
Did the problem start right after installing 8.2.1 or did it actually work until recently?
Is this a local or network installation?
Do you run any kind of firewall software?
Message 4 of 21
(4,775 Views)
I've been working with LabVIEW 8.2.1 for more than a year on my laptop (local install) and it was working fine up until yesterday.
I noticed it that the LabVIEW process itself is what's causing 99% CPU usage with no VIs open at all.
I thought I just need to restart my PC and the problem should go away.
This morning after powering up my laptop & opening LabVIEW its still causing 99% CPU usage.
Mr. Altenbach, here are my responses to your questions:
Does everything still work? YES but obviously very slow.
Is the 99% CPU only for some time duration or forever? How long did you wait? It seems for ever, I've waited for about an hour.
What happens if you open a VI directly? Does the CPU drop? No changes.
What happens if you close the last open VI to go to the welcome screen? Back to 99% CPU? CPU usage never drops
Did the problem start right after installing 8.2.1 or did it actually work until recently? mentioned above
Is this a local or network installation? mentioned above
Do you run any kind of firewall software? N/A
Once again, thanks in advance!
Message 5 of 21
(4,760 Views)
What else happened yesterday? Did you install anything else or changed any configurations? Was there a windows update? Antivirus signature update?
Did you scan the HD for errors?
Message 6 of 21
(4,749 Views)
Nothing happened yesterday, just working on my code which after the LabVIEW problem I was working on another machine with no problems.
I didn't scan my HD for errors yesterday but I did so right now and no problems to report!
Message 7 of 21
(4,744 Views)
Did you mention if disconnecting the network made a difference?
Ben
Message 8 of 21
(4,735 Views)
What network connection? I was working on LabVIEW that was installed on my laptop.
Message 9 of 21
(4,732 Views)
Accepted by topic author LVexpert2b
One thing to try: boot into safe mode. I believe LabVIEW should still work in safe mode, albeit no services will be running. I would be very interested in knowing if the CPU usage is still pegged.
Message 10 of 21
(4,696 Views)
