Invoke Node - Mass Compile Method Error 1043
Hi
I've been attempting to make a simple executable, using LV 2017, to mass compile a specific directory on our systems.
I've used an App Invoke Node and selected the 'Mass Compile' method; it works perfectly well until I build the solution to produce an executable;  once built, running it raises a 1043 error meaning...
The property or method is not supported in this version of LabVIEW. This error can occur if you use a property or method that is not supported in the LabVIEW Run-Time Engine.'
 Quite frustrating as it works perfectly as source code.
Source code attached.
Any help much appreciated..
Les....
(3,107 Views)
Hi Les,
You need to either:
-Manually deploy shared variables from the Project Explorer window by right-clicking on individual variables and selecting Deploy, or by right-clicking the library and selecting Deploy All.
Or, programmatically deploy the library from the host PC using an Application Invoke Node and specifying the IP address for your real-time target:
This KB outlines these steps:
Error 1043 when Programmatically Deploying a Shared Variable on a Real-Time Target
Hope this works for you,
Ben
(3,080 Views)
Accepted by FRL
Hi bkercher
In this very simple project there are no shared variables and it is not a Real-time application;  I suspect that is is simply a case of the method not being supported by the runtime engine.
Many thanks for your response to this thread.
Les....
(3,051 Views)
