Invalid ROI
I am sure you will be having some image processing functions before/after the extraction. I meant you use a unique buffer name (Imaq create name) so that the images dont get over written.
Message 11 of 25
(2,875 Views)
dpg1 wrote:
Edit: I misunderstood (big time)...
No problem i "understood" that :smileyvery-happy:
Message 12 of 25
(2,874 Views)
Haha 😄
Erm I'm investigating something at the moment (Using the IMAQ Histogram VI instead of the Light Intensity Histogram (Rectangle) VI) but I have a quick question - what's the best way to find the miniumum and maximum pixel intensities within and image? Thanks 🙂
Message 13 of 25
(2,865 Views)
Hmm seems that worked 🙂 Thanks for the help and advice 🙂
If you know a way which I can get the minimum and maximum values from the histogram it would be useful still (but not essential - I think :D)
Message 14 of 25
(2,858 Views)
Simply unbundle
Message 15 of 25
(2,855 Views)
Ah but I'm using the IMAQ Histograph VI - is that problematic? Is there a way of getting the maximum and minimum values from this VI?
Message 16 of 25
(2,852 Views)
Why not use a histogram? what is your image type?
Message 17 of 25
(2,839 Views)
It was laziness 😛 It's a grayscale 8 bit image. I've changed now and am using the Histogram function - I didn't realise how easy it was to extract the mean and SD. Can you explain the differences between the two VIs for me? (I'm a bit stupid :()
Thanks again for all your help muks 🙂
Message 18 of 25
(2,831 Views)
To be frank I have never wanted to plot a histogram graph in real time so have never user histograph. from histograph you can get the histogram value but not min/max.
Message 19 of 25
(2,827 Views)
I see - thanks again for all your help - much appreciated! 🙂
Message 20 of 25
(2,808 Views)
