Creating a mesh from nodes (X,Y,Z) and triangular elements file
I'm triying to plot a femur mesh using two files:In the first, there is nodes or vertices coordinates get from CT image, and in the second i have the triangular elements.
I tried the scenemesh application with the SetMeshParms method and triangular Drawmode but the triangles aren't well oriented because I can't set the elements data.So is there a way to plot the 3D model using the nodes and the element data.
Thank you in advance.
Omar.
Message 1 of 1
(2,752 Views)
