Online shopping is currently unavailable.
Please contact us for help or try again later.
Interlinked Button Control
I have a project which requires three buttons: A, B and C.The buttons have a LED in them, and remain pressed until deactivated.
When Button A is pressed in, Button B is disabled (and turned off if it is on).
When Button C is pressed in, Button B is disabled (and turned off if it is on).
When Button B is pressed in, Button A and C are disabled (and turned off it is on).
When Button A and C are independent of each other (Can be both on, both off or on one at a time)
I am going about this using radio buttons and case structures.
Message 1 of 32
(5,717 Views)
Do you have a question?  Are you running into problems?
If so, please post what you have done so far and tell us how it is not doing what you want.
Right now there is nothing in your post that to which we can respond.
Message 2 of 32
(5,707 Views)
Attached is the VI and below an image of the Panel.
Button A is the Detector Station Button
Button B: Manual Storage
Button C: Storage Station
The Detector Station button disables the Storage Station button and vice versa, which is what I dont want. However, I want them to disable the Manual Storage button (as it currently does).
Hope this clear things up!
Message 3 of 32
(5,700 Views)
What is this?
Kind regards,
- Bjorn -
Have fun using LabVIEW... and if you like my answer, please pay me back in Kudo's 😉
LabVIEW 5.1 - LabVIEW 2012
Message 4 of 32
(5,693 Views)
As far as I can understand what you want, this is what I should do.  If not good, it will give you a good start 😉
Kind regards,
- Bjorn -
Message 5 of 32
(5,690 Views)
@ABCPrograms wrote:
What is this?
Typo, should read: Button A and C are independent of each other (Can be both on, both off or on one at a time)
Message 6 of 32
(5,684 Views)
@shultz58 wrote:
@ABCPrograms wrote:
What is this?
That says exactly the same thing.
Message 7 of 32
(5,680 Views)
@smercurio_fc wrote:
@shultz58 wrote:
@ABCPrograms wrote:
What is this?
There is no When, thus the statement is not conditional, it is always true.
Message 8 of 32
(5,678 Views)
Then the VI is your answer 😉
May not be the prettiest one, but it does what it needs to do.  If that's ok with you, please set this post to solved and which answer solved it 😉
Kind regards,
- Bjorn -
Message 9 of 32
(5,676 Views)
It's definately a step forward. And I always give out kudos :). I'm trying to improve the interface by not disabling the buttons, but instead, when a disabled button is pressed, turn off any buttons that violate the conditions i mentioned above. As an example, if i press detector station, and then manual storage button, upon pressing manual storage, its light will go on, and the Detector Station light will go off.
Message 10 of 32
(5,674 Views)
