Interlinked Button Control
Using ABCPrograms response, I was able to contruct the following. It should do what I want. However, I am unsure how to update the cluster I am modifying. If someone can figure out how to apply these changes, we should have a solution to the problem. (Problem solved and kudos will be given!) I feel as if there should be another block after the Bundle by Name block.
Message 11 of 32
(2,002 Views)
How are you going to stop your VI?  It's never going to with the run button outside the loop
Kind regards,
- Bjorn -
Have fun using LabVIEW... and if you like my answer, please pay me back in Kudo's 😉
LabVIEW 5.1 - LabVIEW 2012
Message 12 of 32
(1,997 Views)
mmm, According to me that VI can never work.  Have you tested it?  I don't get your constructions of the AND ports.
Which version of LabVIEW are you using?  and have you tested what I did?  The reaction of the VI is entirely different.
If you tell me which version you're using, I will convert it to your LabVIEW version and you can test mine 😉
Kind regards,
- Bjorn -
Message 13 of 32
(1,989 Views)
Ah, your right. Sorry, Im relatively new to this. What I want the Run button to ultimately do, is stop the while loop. I will then capture the current inputs, and run a specific python script based on the input. Also, after run is hit, I want to the VI to ignore any additional inputs. This is going to be the next step. For right now, I'm look for working input buttons. I'll worry about the rest later.
Message 14 of 32
(1,988 Views)
I am using version 2010. What the and gates do is change the value of the buttons (pressed in or not) so that they dont violate the initial clauses i stated.
Message 15 of 32
(1,984 Views)
What was wrong with the VI I sent you?
Kind regards,
- Bjorn -
Message 16 of 32
(1,983 Views)
Instead of having a button disabled, I want to unpress, or turn on the led for the buttons that violate the conditions I mentioned above. As an example, if I  were to press detector station, and then manual storage button: Upon pressing manual storage, its light will go on, and the Detector Station light will go off.
Message 17 of 32
(1,978 Views)
A simple local variable will solve that problem.
However, as pointed out, the Stop button cannot be outside the loop.Once read, the original value is passed through the tunnel, and from that point on, that's all that the while loop sees. Basic dataflow. You need an event case for the Stop button. Be sure to place the button inside the event case.
The same holds true with the way you're tunneling the cluster, although in this case it doesn't affect you. The value of the cluster gets read and passed into the even structure. The event structure sits there waiting for an event. If the cluster is changed in the meantime, the event structure will not see the new value, as it's seeing the value of the tunnel as it was originally set when the event structure received execution focus. But, in your case this little nuance won't affect the operation.
Also, your Boolean logic doesn't make much sense. (A ^ B) ^ A  is the same as A ^ B
Message 18 of 32
(1,976 Views)
So now you don't want the buttons disabled?
Perhaps it would be best for everyone if you reiterated what you want. Please be clear.
Message 19 of 32
(1,961 Views)
ok, so this is it.  you don't want to use the disable buttons any more, but just want to ise the LED's
See solution in attachement.  Normally we use VI snippet, but have no idea if you know what it is 😉
Kind regards,
- Bjorn -
Message 20 of 32
(1,951 Views)
