Interlinked Button Control
Does a shift register forward its stored data to the output after each loop, or does it forward the final data once the loop halts?
Message 31 of 32
(630 Views)
Any data that is output on a tunnel from a loop will not be available until the loop completes. If you need to pass data out of a loop while it is still executing you have to use a queue, notifier or functional global. Yes, global and local variables will also do the job but I don't recommend their use. There are limited times when they are a valid solution.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
Message 32 of 32
(615 Views)
