How to remove the frame from an ActiveX Web Browser window
I'm using a web browser window to display content from a web application in my LV front panel.  I'd really like the content to appear as native parts of the front panel rather than being inside a frame.  Is there a method that will allow me to hide or remove the frame from the ActiveX control?  I've tried to make it a custom control and edit the decoration out but that does not seem to work.
(3,997 Views)
I can in 8.2 (and newer) drop a Web browser directly from the activeX meny, else you can drop a ordinary ActiveX container, set both colors to Transparent in the toolbox and paint the border.
/Y
Qestit Systems
Certified-LabVIEW-Developer
(3,988 Views)
It seems that a web browser control is required rather than just an ActiveX container.  I can paint the ActiveX container as you state but not the web browser.  It behaves differently.
(3,984 Views)
Quite right, in my 8.2 the web browser is already borderless (probably transparent). If your web browser window doesn't look good you should be able to insert it into the activeX one, the other should be a special case.
/Y
Qestit Systems
(3,967 Views)
Accepted by kc64
My solution is to put the web browser control into a sub-VI and include it in the main front panel using a sub-panel.  By properly framing the front panel of the sub-VI, I can hide the border of the web browser control.
(3,890 Views)
