RT FTP Thread Priority
Is there a way to set the FTP thread priority on a cRIO?  I often need to FTP a large file to my cRIO and it will cause the CPU to spike to 100% which is undesirable.
(4,098 Views)
Hey,
It's set to normal priority, and you cannot change it.
Christian
(4,077 Views)
Every once in  a while while FTPing to a cRIO, I observed the cpu spike briefly to 100% and then I started to receive the following scan engine faults:
Warning 2147137807 occurred at an unidentified location Possible reason(s): The PDO cannot be read because the master is not in OP or SafeOP mode.
I could not find any information on this error.
(4,072 Views)
Hi Sachsm,
It looks like this error maybe caused by a third-party object, such as the operating system or ActiveX.   Can you provide a screenshot of the error?
Starla
(4,054 Views)
Here is a screenshot of the error appearing the the Distributed System Manager.  It is clearly an error from the cRIO Scan Engine.
(4,050 Views)
Thanks sachsm,
Could you post your code also.
Thanks!
Starla T.
(4,028 Views)
