How to remove plot 6, plot 7 and plot 8 from the autopopulate plot menu "Fill Base Line"
Is there a way to remove "Plot 6, Plot 7 and Plot 8"?
Thanks.
J-M
Message 1 of 10
(3,894 Views)
Reduce the number of plots to only the ones you want.
Are you by any chance using an "array to cluster" node somewhere in your code?
Ben
Message 2 of 10
(3,881 Views)
Yes, I use an "array to cluster" node.  It is in a section I removed for the example Test.vi (I removed almost everything).
How can I reduce the number of plots (I have six)?
Thanks.
J-M
Message 3 of 10
(3,856 Views)
Right click >>> Cluster size ...
Ben
Message 4 of 10
(3,849 Views)
I already have a cluster size of 6...
J-M
Message 5 of 10
(3,838 Views)
Since I do not have access to LV I can only offer a guess.
1) Is that cluster you are bundling into have other values not shown in the image?
2) When not running the code try to clear the graph and then right-click and make current the default.
Ben
Message 6 of 10
(3,802 Views)
Have you seen this thread?
You may be out of luck.
mcduff
Message 7 of 10
(3,793 Views)
mcduff,
Unfortunately I think you are right...
JM
Message 8 of 10
(3,757 Views)
Accepted by J-Mv2
0# download Test.vi ‏19 KB
1# Read Legend.Plot Minimum (LegPlotMin) = 9
2# Write 6 = Legend.Plot Minimum (LegPlotMin)
3# right click > replace > graph > XY graph
4# result:
5# warning: as soon as you increase the legend by dragging your mouse too far, above plot number 6,
there will be a new entry in the list
and you can't reset it!
do it right the first time ... Smiley Sad
I guess, you'd better make this a .ctl
still okay:
you've gone too far:
in the latter case, you can only set the plot name from "Plot 6" to " "
(however there is a property node, I only tested this manually )
than there will be an empty entry in the list
manually " ":
result:
Message 9 of 10
(3,740 Views)
Thanks alexderjuengere, it works perfectly!!!
JM
Message 10 of 10
(3,720 Views)
