Showing results forĀ
Search instead forĀ
Did you mean:Ā
How to program cRIO 9039
Hello. I have to program a switch using cRIO 9039 and LabVIEW. This is my first time working with cRIO and I had been reading manuals and userguide but I don't find the information in order to make my first cRIO program. I would be very grateful if someone can write a program like the program I want to make so I can start learning about cRIO programming. Thank you.
(2,184 Views)
Hi Goku,
after reading the cRIO beginner tutorials you should open and learn from the cRIO/Realtime example projects coming with LabVIEW…
(2,168 Views)
So you read the CompactRIO Developer Guide
https://www.ni.com/da-dk/shop/compactrio/compactrio-developers-guide.html
and you still don't know how to program an RIO application?
(2,156 Views)
Im learning how to program cRIO with the NI 9403. All the tutorial I've found are for FPGA programs. Other tutorials use the Digital I/O as a double and I just can work with them as a boolean and I don“t understand why.
(2,127 Views)
Hi Goku,
start with cRIO basics, like presented here.
Me neither. Never had any examples for digitalIO using DBL datatypes. Mind to link to those (bad) examples?
(2,122 Views)
