How to install OpenG libraries?
long time ago i installed the openG libraries. Now i need to reinstall a pc and have some problems.
Labview is 2014
vpm is running and database updated
In Google i found a vpm-link at
http://www.ni.com/gate/gb/GB_EVALTLKTOPENG/US
In here is a download-link that opens the VI Package manager. In the vpm appears a "We have moved logo" and "Labview Tools Network".
Then i click there on download which opens the InternetExplorer at:
http://www.ni.com/labview-tools-network/d/
On this website is again a search-bar where i insert "OpenG" but the results brings me back to the first link...
How can download OpenG?
Thanks for help
Message 1 of 8
(10,081 Views)
Accepted by OnlyOne
One quick thing you can do is search in vipm itself for OpenG and install.
-Or download file in this link and open with VIPM to install: http://forums.jki.net/topic/567-how-to-install-openg-vis-manually/
Edit: the sourceforge link is here: https://sourceforge.net/projects/opengtoolkit/?source=navbar
uday
Message 2 of 8
(10,068 Views)
Ok, searching in VIPM worked.
I compared the installed openg-parts on the old pc and manually selected them on the new pc in vipm.
Message 3 of 8
(10,057 Views)
It's 2025, 11 years later and I too am running around in the same circle.  You follow the links provided by LabVIEW and you and eventually you just get back to the first link.....
Can anyone provide the actual "click this link to download" link?
Message 4 of 8
(1,732 Views)
Use VIPM and search for OpenG:
Tim
GHSP
Message 5 of 8
(1,721 Views)
It looks like you can also install the open G libraries through the NI package manager.
Tim
GHSP
Message 6 of 8
(1,664 Views)
I tired the package manager and it did something, but what that something is I haven't figured out.  It appeared to install version 3 when the most recent version is 6.  I tried linking whatever it is that installed to the tools palette but couldn't find any means to do so.  The package manager knows that version 3 is installed, but LabVIEW doesn't. I did find a library of routines that can be used to work with gifs which is my immediate project.  I will post the library later.
Message 7 of 8
(1,659 Views)
I uploaded a library of gif tools I found.  These work.
Message 8 of 8
(1,635 Views)
