Linx install on a Raspberry pi 3B
Hello
Recently i have installed LabView 2023 Q1 community edition and i want to use it in combination with a Raspberry pi 3b.
When i go to the installation tab in the target configuration and select upgrade it show "Target configuration updated" but the installed version box is empty
I have attached the log file.
When i try to launch the blink example in Labview and try to connect to the Raspberry pi in the project window by right clicking and select connect, LabView gives me the error "Unable to resolve from current dialog"  Failed to connect to the target. Even though the IP number is correct
What could be the problem
Thanks for help in advance
(3,328 Views)
@MyControlLab wrote:
Hello
LV Community Edition already has LINX, but it's called "Hobbyist" now.  I don't know the course of action to take, however, because NIPM complicates things so much.  You probably should uninstall LINX using VIPM, then uninstall LabVIEW itself and all the stuff that goes along with it, then reinstall LabVIEW.
Bill
CLD
(Mid-Level minion.)
(3,311 Views)
It's hard to tell from the linx log (lots of internals will still reference the old Linx name instead of Hobbyist) but since you're saying Linx I'm thinking maybe you have installed Linx from VIPM after installing LV 2023CE... which will tend to break Linx/Hobbyist. Community edition already comes with hobbyist installed from its offline installer as billko stated. You may get some luck from uninstalling LabVIEW from NIPM and then running the 2023 offline installer again. Hobbyist will already be installed and available in the tools menu.
There are also premade Pi images made with LabVIEW pre-installed that you can grab from https://github.com/MakerHub/LINX/wiki/Installing-an-image-with-LabVIEW-pre-installed
~ Helping pave the path to long-term living and thriving in space. ~
(3,276 Views)
Hi, has anyone made this to work? Seems cannot connect to target. I flashed LV2021 prebuilt version.
(1,574 Views)
