How to install Microsoft PowerPoint Object Library
I want to control Microsoft PowerPoint by ActiveX. But I cannot find Microsoft PowerPoint Object Library from type library. Could anybody share with me about how to install Microsoft PowerPoint Object Library?
1. Operation system: Windows 10, 64 bits
2. Labview 2021, 32bit
3. Microsoft PowerPoint 2019
(6,237 Views)
You can check this example code for reference
https://forums.ni.com/t5/Example-Code/Controlling-MS-PowerPoint-with-ActiveX-and-LabVIEW/ta-p/399636...
Since I don't have power point installed I cannot exactly find its type library.
CLD Using LabVIEW since 2013
(6,182 Views)
thanks! but your link is talking about how to use ActiveX to control Powerpoint.
My problem is about how to install PowerPoint Object Library.
(6,177 Views)
Accepted by DavidWei
The PowerPoint library file is msppt.olb. You have to add it manually.
for 32bit You can find it in Program files(x86)/Microsoft Office/Officexx.
for 64bit You can find it in Program files/Microsoft Office/Officexx.
In select object from library window, click on browse and go to above mentioned location and then select the file. You shall be able to see in the library list then.
(6,172 Views)
Nice! I find it!
(6,162 Views)
