Example Code
Controlling MS PowerPoint with ActiveX and LabVIEW
Code and Documents
This VI uses ActiveX to launch Microsoft PowerPoint and run a presentation you specify. You also can specify how long each slide displays before continuing.
After the last slide, LabVIEW generates an error that causes this VI to close all references to the presentation and then quit PowerPoint.
Contributors
