How to execute "Mass Compile" in my own Installshield?
I have to create my own distribution with
Installshield.
I don't know how to run automatically the Mass Compile at the end of the installation procedure.
(3,174 Views)
You will need to create a VI that calls the "Mass Compile" VI Server Application Method. Have install shield launch this VI via a command line and have the VI set to "run when opened".
Good luck,
Jim
(3,174 Views)
ok, i belive that
but i dont want, that the user have to enter the the path of the directory which i want to compile....
... and there is no possibility to use the "masscompile.vi" as an subvi(no terminals on Connector)
so, what to do?
(3,174 Views)
You can just include a contstant for the path of the folder that you want to mass compile. You don't have to make your user choose that. This is really the only way that I can see for you to do this. If you make it into an executable, it can run without them ever seeing.
J.R. Allen
(3,174 Views)
