Upto 10KS/s is the specification for the card you are using as mentioned in the data sheets and it is system dependent.
http://www.ni.com/pdf/products/us/2mhw249-250e.pdf
So most likely you will get 10KS/s or less update rate depending on the speed of your system.
Sincerely,
Sastry V
