キャンセル
次の結果を表示
次の代わりに検索
もしかして:
How to calculate slope of XY curve?
解決済み
解決策を見る
Hi all,
I want to calculate the slope of a X-Y curve, for example, amplitude v.s. position. I was trying to use the derivative method but failed. Could anyone help me with this problem? The example vi. is attached.
Nicky.
メッセージ1/10
15,700件の閲覧回数
解決策
受理者 Nicky87
Like this
Tim
GHSP
メッセージ2/10
15,694件の閲覧回数
Dang it, too slow...
Try the Linear Fit VI
メッセージ3/10
15,692件の閲覧回数
Although it involves a Rube method as compared to Linear Fit, the attached vi teaches what a slope really is.
- tbob
Inventor of the WORM Global
メッセージ4/10
15,624件の閲覧回数
Can you post the same solved example with labview 8.2?
0 件の賞賛
メッセージ5/10
15,301件の閲覧回数
Here is an 8.0 version.
Tim
GHSP
0 件の賞賛
メッセージ6/10
15,284件の閲覧回数
Hey
Attached is the Vi.
Could you please help me if I want to find the slope and I want to stop the loop and measurement when the maximum slope has been attained.
Help will be very much appreciated.
0 件の賞賛
メッセージ7/10
15,256件の閲覧回数
How are you defining "maximum slope".  Is it a simple threadhold (stop when slope >= a set value) or are you looking for the inflection point (calculating on the fly the maximum slope and stopping when it is reached)?  The threshold is a simple comparison.
GCentral
0 件の賞賛
メッセージ8/10
15,251件の閲覧回数
No it is infection point, as in after getting the measurement value , finding the slope and stopping when the slope is highest as in it has maximum deviation from the previous value.
0 件の賞賛
メッセージ9/10
15,249件の閲覧回数
You should be having a Max limit value so that you can compare on the fly and stop if the max slope is achieved. Check the attached example and also keep it in a single thread
Good luck
0 件の賞賛
メッセージ10/10
15,223件の閲覧回数
