How to build a TCP client in LabVIEW to receive webcam video from Python?
I have a Python TCP server that streams webcam video frames as JPEG over the network. Now I want to build a LabVIEW client that can:
  • Connect to the Python server
  • Read the first 4 bytes (frame length)
  • Receive the JPEG frame data
  • Display the image on the LabVIEW Front Panel
Note: I do not have NI Vision Toolkit, so I need a solution using .NET (MemoryStream + Image.FromStream) or any other method to display the image.
Can someone share a simple example VI or block diagram to achieve this?
Thanks 🙏
(414 Views)
Body:
Hello everyone,
I have a Python TCP/IP server that streams webcam video frames as JPEG data. The code is below:
import socket import cv2 import numpy as np import struct def main(): HOST = "127.0.0.1" PORT = 5555 server_socket = socket.socket(socket.AF_INET, socket.SOCK_STREAM) server_socket.bind((HOST, PORT)) server_socket.listen(1) print(f" Server ready on port {PORT}...") conn, addr = server_socket.accept() print(f"📡 Connection from: {addr}") data = b"" payload_size = struct.calcsize("L") # 4 bytes for frame length while True: # get frame size while len(data) < payload_size: packet = conn.recv(4096) if not packet: break data += packet if len(data) < payload_size: break packed_msg_size = data[:payload_size] data = data[payload_size:] msg_size = struct.unpack("L", packed_msg_size)[0] # get frame data while len(data) < msg_size: data += conn.recv(4096) frame_data = data[:msg_size] data = data[msg_size:] # decode and display frame = cv2.imdecode(np.frombuffer(frame_data, dtype=np.uint8), cv2.IMREAD_COLOR) cv2.imshow("TCP Server - Received Video", frame) if cv2.waitKey(1) & 0xFF == ord('q'): break conn.close() server_socket.close() cv2.destroyAllWindows() if __name__ == "__main__": main()
What I need help with:
👉 How can I build the LabVIEW client that connects to this Python server, reads the data, and displays the video in real time?
Specifically:
  • How to use TCP Open Connection.vi and TCP Read.vi to receive the 4-byte length prefix and then the JPEG frame data.
  • How to decode the received JPEG byte array into an image in LabVIEW. (I don’t have the NI Vision Toolkit, so I may need to use .NET MemoryStream + System.Drawing.Image.FromStream.)
  • How to continuously display the frames on the LabVIEW Front Panel.
If anyone has a small VI example or block diagram screenshot, it would be a huge help 🙏
Thanks!
(390 Views)
Accepted by azerader47@gmail.com
As a very first step I would like to recommend to take a look on any VI which is able to convert JPEG string to 2D array, like this example — jpeg string to picture, the start with code like this:
(382 Views)
It would seem to me that you somehow are mixing up client and server here. Your webcam_tcp_client is a TCP client but you talk in your post about a server, which it kind of is in terms of webcam functionality, but still it makes things a bit confusing.
Other than that there are a few other inconsistencies. Your webcam server which assumes the TCP client role tried to connect to port 9999, but your webcam client which assumes the TCP server listens on port 5555.
One other point: you use whatever endianess is the native one on either side. While it is fairly hard to find hardware that uses BigEndian format nowadays it does exist and is coincidentially the default for network data transfers. You definitely should always decide on an explicit endianess when streaming binary data over a network connection as the remote side definitely could reside on a hardware with a different native Endianess.
LabVIEW's Typecast function happens to assume BigEndian too, but that has mostly historical reasons since LabVIEW originates from the Mac where it originally ran on Motorola 680xx hardware which happened to be a BigEndian architecture.
Changing your struct.pack() and struct.unpack() format codes from "L" to ">L" will make sure the number is transfered as BigEndian and you can forget the ReverseString node in the example posted by Andrey.
Rolf Kalbermatter  My Blog
(305 Views)
Thank you for your help, my dear friend. But I tried the program, and unfortunately, I couldn’t capture an image from Python. Is there another way to capture webcam video using Python?
"And my LabVIEW version is 2023 64-bit. Won’t the code work in my LabVIEW?"
(290 Views)
