Labview Remote front panel
Hi all,
I had developed the server and client for taking remote control from server PC Vi to Client PC, and it was working, but when I made an exe in server PC which is the same VI to access in client PC, but Client PC is not connecting to the server PC Vi for taking remote control. For developing the Remote front panel, I had used the example given by NI in the example section Remote Panel Methods.lvproj.
Kidelly, let me know before converting the exe whether I need to configure anything on the remote front panel to make it work with the exe.
(1,761 Views)
It would really help us to (better) help you if you attached the VIs that you are using in your tests.  Among other things, it would tell us something about your LabVIEW Version (which, if you are using LabVIEW 2025, many of us might not have installed, but at least we'll know the name(s) of the Example).
(1,716 Views)
Tq for the reply.
I am using the LabVIEW version of 2024 Q3. I had attached the example project by down-converting to 2020
(1,669 Views)
I haven't done this sort of thing recently, but it looks very much like NI "Example code", which means it is probably "correct" and maybe you just haven't set it up correctly.  I'm (reasonably) certain that in a day or so, Forum participants familiar with Remote Front Panels will be able to make useful suggestions for you to try.  Please be patient ...
(1,646 Views)
The example code is working with the VI, but when I convert to exe, it is not working but finally i want to make it with exe.
(1,611 Views)
I know you want to build an Executable, but is it for the Client, or for the Server?  I don't have direct experience with LabVIEW's Remote Panel Methods, but I'm "guessing" that while the Client might be able to run as an Executable, it is not clear to me that the Server can do so.  I hope one of my colleagues (or part of the LabVIEW Development Team) can provide some clarification.
(1,585 Views)
