02-07-2021 01:25 PM
Can you instead attach a simple VI containing the two images as data (e.g. as diagram constant)?
(Looks more like contrast enhancement. Can't you just remap the color table? Another option might be wavelets (see also))
02-07-2021 05:22 PM
you need to install python3.7 to use this vi and LabVIEW x64bit 2020
attached vi with image place them at the same location and run this.
Now you can suggest a simple approach or any predefined or built-in filters that may available in wavelets or advanced signal processing toolkit.
02-07-2021 07:04 PM - edited 02-07-2021 07:05 PM
this is an attempt to translate gptshubham595 's python script to labview
EDIT: if I feed the coin.jpeg into this .vi, the output is slightly different than in the actual python script
02-08-2021 05:22 AM
I forgot this part in my snippet above:
I read the image in labview, normalize to 255 and feed this 2d array to the python script and to the labview code.
the calculated output is similar but not identical:
attached as .zip is the correct .vi, the python script without opcencv img.read and the coin.jpg
02-08-2021 07:53 AM - edited 02-08-2021 07:55 AM
Thank You! I'm in love with this community now.
I tried something similar for this you can check my first solution posted for this.
python was giving better result don't know why.
02-08-2021 09:45 AM
@altenbach wrote:
I think all you need to do is a 2D convolution with a 2D Gaussian. Code should fit a postage stamp. No Python.
I'd love to see a solution based on
https://zone.ni.com/reference/en-XX/help/371361R-01/lvanls/convolution/
the issue with this is, that the kernel is not a constant (as it is usually), but does change from position to position when moved accross the input image.
I suppose, we could test this with the opencv implementation as ground truth.
