How to apply bilateral filter over a 2d matrix image
Can you instead attach a simple VI containing the two images as data (e.g. as diagram constant)?
(Looks more like contrast enhancement. Can't you just remap the color table? Another option might be wavelets (see also))
Message 21 of 26
(2,393 Views)
you need to install python3.7 to use this vi and LabVIEW x64bit 2020
attached vi with image place them at the same location and run this.
Now you can suggest a simple approach or any predefined or built-in filters that may available in wavelets or advanced signal processing toolkit.
Message 22 of 26
(2,380 Views)
this is an attempt to translate  gptshubham595 's python script to labview
EDIT: if I feed the coin.jpeg into this .vi, the output is slightly different than in the actual python script
Message 23 of 26
(2,367 Views)
I forgot this part in my snippet above:
I read the image in labview, normalize to 255 and feed this 2d array to the python script and to the labview code.
the calculated output is similar but not identical:
attached as .zip is the correct .vi, the python script without opcencv img.read and the coin.jpg
Message 24 of 26
(2,346 Views)
Thank You! I'm in love with this community now.
I tried something similar for this you can check my first solution posted for this.
python was giving better result don't know why.
Message 25 of 26
(2,334 Views)
@altenbach wrote:
I think all you need to do is a 2D convolution with a 2D Gaussian. Code should fit a postage stamp. No Python.
I'd love to see a solution based on
https://zone.ni.com/reference/en-XX/help/371361R-01/lvanls/convolution/
the issue with this is, that the kernel is not a constant (as it is usually), but does change from position to position when moved accross the input image.
I suppose, we could test this with the opencv implementation as ground truth.
Message 26 of 26
(2,320 Views)
