How to access common global variable between different Packed Project Library
Accepted by topic author DanielDu
DanielDu wrote:
     As an alternative option, I would like to make sure Test Task.lvlibp calls the version from DataProcess.lvlibp. But I can not imagin how to implement it.
The simplest solution is multiple projects.  You have a project for DataProcess.lvlib to build DataProcess.lvlibp.  You then have DataProcess.lvlibp in your main project where Test Task is used.
Message 11 of 12
(1,597 Views)
    Thanks for your new idea !
    I am not very clear about "how to refer to the queue by name in each PPL?"
Message 12 of 12
(1,597 Views)
