How to access common global variable between different Packed Project Library
My project consist of several library , after build the Packed Project Library for each library, I find it can not shares data in global variable between different packed project library file. For example: Packed Project Library #1 Contains VI to wirte global variable "position" and give its a value "400". Packed Project Library#2 Contians another VI try to read this global variable, but it read out is NULL not "400". Why this happened? Is there any way to solve it, welcome to any help,I wll appreciate for that!
Message 1 of 12
(10,320 Views)
The global variable is part of the PPL?
I am surprised if that works during development... You are running into the issue that the lvlib (the basis for PPL) is creating a name space. So you are NOT using the same global even if you have the same VI name for the global variable and the same name for the data field itself.
Norbert
Norbert
Expert: Geometry
Message 2 of 12
(10,315 Views)
You would need to build your global variable into it's own 'shared components' PPL and then use the version from the PPL in the other PPLs/VIs.
(blog)
Message 3 of 12
(10,313 Views)
Hello Sam, Actually I think I am doing like this, they are referece the same global variable.
Message 4 of 12
(10,305 Views)
Attached Picture
Message 5 of 12
(10,300 Views)
Hello Sam&Norbet,
   Sorry, I have some issue when upload picture. Now,you can see my project.  For easy understand this issue, I creat two easy VI to demostrate it.
   You can see this global varible is defined in an llb, and can be access by another llb.  However, after build PPL,it can not be accessed
Message 6 of 12
(10,290 Views)
If you create a PPL for DataProcess (which contains the global variable), you have to swap the global variable in TestTask to the one from the PPL "DataProcess".
Norbert
Norbert
Expert: Geometry
Message 7 of 12
(10,281 Views)
Accepted by topic author DanielDu
So you understand what's happening here...
When you build a PPL, it pulls in the .lvlib and also all of the dependencies of the .lvlib.
In your case, when you build Test Task.lvlib into a .lvlibp, it also pulls in a copy of DataProcess.lvlib:GlobalsVariable.vi because it is a dependency of Read GlobalVar.vi.
When your application runs, you end up with two copies of GlobalsVariable.vi in memory:
DataProcess.lvlibp:GlobalsVariable.vi
AND
Test Task.lvlibp:<dependencies>:GlobalsVariable.vi (I'm not sure how PPLs namespace dependencies...whether it's still got the DataProcess.lvlibp)
Because they are different VIs (i.e. in a different namespace), they have their own memory and that's why you can't access the data from the other one.
Your Test Task.lvlibp calls the version of GlobalsVariable.vi it has pulled in from the dependencies.
To fix this - you need to make sure that Test Task.lvlibp calls the version of GlobalsVariable.vi from the DataProcess.lvlibp - you'll need to replace all instances with the version from the PPL. Of course, if you're running DataProcess in the development environment, then it will still be incorrectly namespaced, hence the suggestion of putting your global variable VI into it's own PPL which you then use in both Data Process and Test Task.
(blog)
Message 8 of 12
(10,271 Views)
As a side note (the other responses are spot on and I can't add anything there) - there are other cheeky ways fo creating a "global" that can be accessed from multiple PPLS as long as they are used in the same application (ie. Application Instance).
A common one I have used before in situations where dependences were simply too tangled to justify the time to manually untangle them is a single element named queue (the name being the important part here). Queues (in particular named queues) are unique in each Application Instance. I you refer to the queue by name in each PPL (and hope for no conflicts - so choose a particular obtuse name or something with some confidence of uniqueness such as a GUID etc.) then the queue will be the same reference in both PPLS at run-time when used by your calling application (your hosting Application Instance).
You can stuff data in and out of them with another advantage being that you can control the operation atomically if needed through an API to the SEQ.
Message 9 of 12
(10,247 Views)
Hello Sam&Norbet,
    Thanks for your help, Now I understand why it can works in development enviroment but can not works in application enviroment.
     It is right to put global variable in its own PPL,but I don't like use this solution,because it will make my project organization structure not easy understanding.
     As an alternative option, I would like to make sure Test Task.lvlibp calls the version from DataProcess.lvlibp. But I can not imagin how to implement it.
     Thanks!
Message 10 of 12
(10,214 Views)
