List of files and subfolders in a folder
hello everyone
            I want to List of files and subfolders in a folder,display use List box,at the list box.Each line in the front of the display file type icon.Behind the display name of the file. I check the related information,somebody use List the folder functions and Initialize the array,at the Initialize the array,it is connected Enumerated constants,can choose file and floder.so, I want to know how to do.
    thank you  very much!
    best regards for you!
(7,061 Views)
I don't think that what you are interested in doing is very hard. There is a low-level function in LabVIEW that will list the files and subdirectories in a starting path. Does this need to be done recursively to any depth? If so the is a built-in function that will list all files and folders under a given starting directory.
More confusing is the issue of displaying the results. Could you perhaps draw sort of a mock-up of what you wanting to create? You mention icons, what sort of icons? General symbols to distinguish between files and folders, or unique icons like in Windows explorer?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(7,056 Views)
If you just need to list the files or folder inside a main folder, then list folder will gives you proper output.
Else if you need to get list of all folders,sub folders,and files inside a root directory you can use recursive path functionality it's like (*.*) functionality in Windows
As Mike suggested share us the code you tried and brief us more about icons that you are referring.
Pazhanivel Thiruvenkadam,
CertifiedLabVIEWArchitect|| CertifiedTestStandDeveloper,
Currently able to Access LV2015&LV2017
(7,051 Views)
Hi hereby ihave attached the simple vi which does simple files and folder display with symbol, whereas if u want some event to happen on selecting the folder to show files, use tree control.
(7,048 Views)
First of all, thank you very much for your answer.After a lot of search, I found that it is called a list box symbols, please see the appendix.
(6,939 Views)
(6,938 Views)
