How make for loop with min max value ina Array
Something i do in C in one minute in LabView take me 20 hours this blow my mind.
Message 31 of 55
(2,028 Views)
I can do it in LabVIEW in 20 seconds. 😄
For some entertainment, see here .... 😄
Message 32 of 55
(2,024 Views)
So help me xd, only with MAX. I have more exercise - with convert dec to boolean and sort array without using Sort Array 😕
Message 33 of 55
(2,019 Views)
Sorting is a different problem. Solve the first problem first.
Message 34 of 55
(2,012 Views)
Only with MAX help me i need to know how this should look. To do MAX i need only one shift register?
Message 35 of 55
(2,007 Views)
Yes.
Message 36 of 55
(1,993 Views)
And i should to use Index Array?
Message 37 of 55
(1,986 Views)
Yes
Message 38 of 55
(1,966 Views)
So one index array, one case, one numeric indicator, something more?
Message 39 of 55
(1,953 Views)
You don't need any case. use min&max. Also don't forget the shift register. You also need an input array, a FOR loop, a diagram constant to initialize the shift register, and some wires. 😉
Message 40 of 55
(1,939 Views)
