Average Random Numbers
So what I need to do is generate a series of random numbers. I've got that.
However, the tricky part is I need to average the current random number and the previous 3 random numbers and output that on a waveform chart.
Any help or pointers would be awesome. Thanks
(3,981 Views)
Accepted by topic author Yaketysax
Easy peasy. There's a VI called Mean Pt by Pt. Set your buffer to 4 and it will average the current input with the last 3.
Cheers
--------,       Unofficial Forum Rules and Guidelines                                           ,--------
          '---   >The shortest distance between two nodes is a straight wire>   ---'
(3,975 Views)
Thank you!
(3,966 Views)
