How make for loop with min max value ina Array
@crisdragon wrote:
It can be two numeric indicators in output. All time i try everything but is not easy convert from C to VI.
You don't need to convert anything. Just think from first principles.
You also need some minimal knowledge about LabVIEW, of course. That's why you got the link to tutorials earlier. You cannot translate into a language that you are not familiar with.
Message 21 of 55
(2,329 Views)
One array, comprare t[i]>=t[i+1], t[i]>=t[i+1] etc. if true t[i+1]= t[i] and its all, why i cant do this?
It is possible to do this without shift registers?
Message 22 of 55
(2,322 Views)
@crisdragon wrote:
... why i cant do this?
Because you haven't done any basic LabVIEW tutorials. 😄
If this is for school, maybe you missed a few days of lessons? Ask your classmates for the class notes and study materials.
Message 23 of 55
(2,317 Views)
Earlier, you said that you can't use array min&max. Now you don't want to use shift registers?
Is this now an additional hard requirement or just an irrational fear of the unknown? 😮
A shift register (or feedback node) is a central and one of the most important features of LabVIEW. For a scalable solution with input arrays of any size, you most likely need a shift register to keep the currently largest and smallest element found (Of course you could use local variables, but let's not uglyfy the code even more so don't do that!). Make sure to initialize the largest with -inf and the smallest with +inf.
Message 24 of 55
(2,313 Views)
I think Shift Registers are strange and freaky. I think i am on good way but i dont know how write MAX value (is in the case) to array[i+1] because MAX value is indicator and Array is Control 😕
I know you are all laughing for me. This is easy but i am very very new and i try to understand everything.
Message 25 of 55
(2,304 Views)
A scalar shift register represents a single persistent memory location where you can read the content at the beginning and write to at the end of each iteration. Nothing freaky about it at all.
Did you ask your classmates about the lecture notes you missed?
Message 26 of 55
(2,280 Views)
I think i have all notes but i dont know how take advantage for them. OK I give up, i need to watch some tutorials. But this what i add below is closer end or start or looks like "shi*"?
PS. LabWindows is simpler
Message 27 of 55
(2,270 Views)
You think Labwindows is simpler because it is text based like C is.
Quit thinking of shift registeras and associating it with the array and as T(i) and T(i+1).  You don't even have to worry about the indexing of the array because it will happen automatically for you with auto-indexing tunnels.
You need to worry about the memory location that stores the MIN value, and the memory  that stores the MAX value.  Those are scalars and the ones you store, each one has its own shift register.
Message 28 of 55
(2,254 Views)
I try do only MAX and i cant. 😕 I have no more ideas
Message 29 of 55
(2,245 Views)
I have no more ideas on how to explain it to you without actually doing your homework for you.
Sorry.
Take the tutorials.
Message 30 of 55
(2,238 Views)
