How do I programmatically change the color of an entire tree control?
Any help is appreciated.
Message 1 of 9
(6,293 Views)
Hi Chris,
which color do you want to change?
Did you try property nodes?
Message 2 of 9
(6,287 Views)
Crosspost
Looking at the property nodes available I would have guessed it was Cell Background Color, but that is only for one cell.  You could iterate over all rows, and all columns, but this gives an error if there is no data there.  It might not be possible to do at run-time.
Message 3 of 9
(6,282 Views)
You can make use of property node (Active cell background colour) but you will have to put logic to change active cell position from first row first column to last row last column.
With Regards
Miraz
Kudos is better option to thank somebody on this forum
Message 4 of 9
(6,278 Views)
Accepted by chriscarner
Use a property node.  Set the "Active Item:Row Number" to -2 (all rows).  Set the "Active Cell:Active Column Number" to -2 (all columns). Set the "Active Cell:Background Color" to the desired color.
Message 5 of 9
(6,269 Views)
New learning for me today. Thanks
Message 6 of 9
(6,263 Views)
Hi Anand,
it's all in the help! 🙂
Message 7 of 9
(6,259 Views)
@GerdW wrote:
Hi Anand,
Thats my ignorance 🙂 I never read the material nor the help file unless I get stuckup somewhere. Thanks GerdW for pointing the help.
Message 8 of 9
(6,251 Views)
Thanks for all the quick replies, and for the answer!
Message 9 of 9
(6,247 Views)
