pfi
hi
i am trying to measure the pulse width from a sonar output for a robot, i need to use a gate(pf14/gpctr1_gate) for that ,my daq device is 6025e ,it has a gate which can be configured as a input or an out put ,to do that i have to set the gate to out put or input using PFI ,this is where my problem is i donot know how to set the gate ,so can some one please tell me how to set this gate to out put or input ,i need to set this as input
thanks
bye
(3,202 Views)
See
http://exchange.ni.com/servlet/Redirect?id=8749694
(3,201 Views)
I'm new to Labview and I've been working off of someone else's program.  I need to know how to set a PFI pin, from the DAQPad-6070E, as an output.  How do I do this?  I'm using the output from this pin to trigger my predecessors program.  Right now he has an external trigger source.  I need to remove the need for this external trigger source by turning an output signal from one of the PFI pins on the DAQPad as a trigger signal.  Can you help me?
Thanks.
J
(3,078 Views)
Hello jtanabe,
Please see the discussion forum found here.
Jesse O.
Applications Engineering
Jesse O. | National Instruments R&D
(3,054 Views)
