Hiring Developers and Licensing
Following these links about Deployment and Debug LicensesLicensing Options
Software Products that Require Deployment Licenses and Deploying a RT Startup Executable without the LabVIEW IDE?.
If I hired and paid a developer for programming and compiling an application for a NI cRIO system, and if the developer has the Debug Licenses: LabVIEW Development System, LabVIEW FPGA Module, and|or LabVIEW Real-Time Module, should I, as final contractor, have to purchase licenses for any of these products on my name?.
I understand i have not, because i am subcontracting the services, and i am not developing LabVIEW executables.
Message 1 of 13
(4,591 Views)
That depends on two things:
1) Your agreement with the contractor: It is not uncommon that the contractor uses the license of the entity that wants a system to be developed.
2) If you ever intend to be able to look at the code yourself afterwards.
If you leave everything to the contractor including the whole source code you put yourself into a somewhat vulnerable position, especially if things should end up to not run smoothly. Even if your agreement guarantees you the rights on the source code this means nothing if you don't have a LabVIEW license to actually look at that source code and make changes or let another party make changes to it at a later stage.
Rolf Kalbermatter  My Blog
Message 2 of 13
(4,557 Views)
In addition to what I wrote earlier, the Debug license is not enough to develop the application. Your contractor would also need to own a full development license with the relevant Toolkits in order to be legal. The debug license is only meant to be used on the final target system for debugging purposes and minor code modifications that result from debugging the software, not for the actual development work.
Unless this is about a turn-key solution where you wouldn't care at all if the solution is written in LabVIEW, Python, assembly or Marsian, I would think it to be more sensible choice to have your contractor own the full development license of LabVIEW for the development work and add a debug license to the cost of the project for your own use. That way the software is tested on your hardware with your debug license and if you ever need to have someone look at the program for debugging purposes after the whole software has been delivered, you can do so without having to jump through hoops and loops first.
When we propose such projects we regularly include a debug license into the quote. The customer may never really use it themselves but it gives them ease of mind to know that they can do it if the need should arrive.
Message 3 of 13
(4,517 Views)
Rolfk is on point, and I just wanted to add my experience.  I worked for an integration company that would get hired to do work.  Some times it would be software only work and the customer had the hardware in mind and purchased and just needed someone to whip up some software and integrate it.  In these cases the customer would usually pay a flat amount for some amount of functionality based on a list of requirements, and regular meetings on the progress of the software.
Then I would go on site with the software to deploy it and make sure it works with the whole system.  Everything that could be tested before this point should be but somethings just can't be simulated like network infrastructure.  At this point the contract turned into an hourly rate until the customer was satisfied.  We would provide the source, and a built executable.  In some cases the customer would request we purchase a full development license to install on the deployed machine so that they could open, and edit the source after we were done.  But in most cases the customer just wanted the source, and if things stopped working would rather call us up to fix it, then try to do it themselves.
So in my opinion if you hire someone to do work for you, they should be expected to have the tools to do the work, including a development license.  But having the source available, is important in case things go sour with the hired company afterwords.
Message 4 of 13
(4,484 Views)
Re: wanting the source code...
Recently I ran into that issue with two customers.
Spoiler
In one case the original group had their own proprietary framework developed in LV but deployed as a exe. They developed custom plug-in for the customer and provided those VIs but not the source of the framework. Since the changes I was being asked to quote required changes to the framework, and the source code was not available, I could only offer a complete re-write of the application while the original company was able to quote based on having control of the original framework. Sorta frustrating not being able to even offer a reasonable alternative.
In the case of the second the original developer password protected some of the components used in the otherwise non-pass-worded code and refused to provide the password. The end customer was very unhappy with the previous developer and when learning they were holding the application hostage, instructed me to quote what was required to eliminate the previous developer from the game. I liked his attitude!
Ben
Message 5 of 13
(4,472 Views)
You know its funny, people always say that the diagrams are locked because the want to protect their "intellectual property" but somehow it always seems that when I do get access to the code it turns out that the code stinks on ice.
And yes 3rd party VIs with block diagrams that are locked are useless. You see the problem all lies in the phrase "...if the VIs do what you want...". They typically don't and with locked diagrams you can't fix the problems.
-- Mike Porter
Message 6 of 13
(4,465 Views)
-- Mike Porter
It is  shame I can only offer you one Kudo for that post Brian.
Judging based on the code around the protected sub-VIs, I can pretty much duplicate them if I wanted to do so but since they are part of the faulty architecture that I will be replacing, good ridens!
Ben
Message 7 of 13
(4,457 Views)
Dear rolfk
1. No i dont have any NI software licenses, and i dont intend to purchase them in the future.
2. It indeed would be wise to have the source code.
I am actually wanting the system wrote a tdms streaming from their pick ups continuously 24/7, without any specific case.
Besides, where should i find a proper developer able to perform this work?
Message 8 of 13
(4,405 Views)
@rolfk
I am assuming the contractor has a LabVIEW Development System, and that the code should not use any specific toolboxes, besides the mentioned (FPGA Module and Real Time Module).
...where you wouldn't care at all if the solution is written in LabVIEW, Python, assembly or Marsian...
I am sure you cannot make a NI hardware run by using Python or any other language, or it is possible?.
Message 9 of 13
(4,402 Views)
@Ben,
Thanks for sharing your experiences :).
Message 10 of 13
(4,400 Views)
