05-29-2007 10:35 AM
What am I doing wrong in my code?
Alex
05-29-2007 03:52 PM
05-29-2007 04:03 PM
I am afraid I cant seem to open it, as I only have Labview v8.0 and not v8.2 (NI drives me nuts sometimes).
Would it be much to ask for a print screen (or if it is possible in V8.0)?
All the best
Alex
05-30-2007 03:43 AM
Hi Alex,
Heres the vi in version 8.0 of LabVIEW
Hannah
NIUK & Ireland
05-30-2007 08:07 AM - edited 05-30-2007 08:07 AM
Thank you for the assist HannahW!
Sláinte,
-Mello
Message Edited by Mellobuck on 05-30-2007 08:15 AM
05-30-2007 09:47 AM
Thanks for you reply.
This is what I was trying to accomplish.
I have, however, one more question. I cant seem to get the the HV Conductor Current to start from 500 and stop at 1000.
When I reduce the initial value to 400 I only get until 900. When I increase the initail value to 500 the graph starts from 600-1000.
Why is this?
Alex
05-31-2007 07:51 AM
Hmm, I am not sure
When I run th eprogram I get from 500-1000 - however, the 500 is 'farthest away' on the 3-D plot and kind of small. Is it maybe getting lost on you monitor resolution? I've never really used this Xcontrol, and I can't immediately find a method to programmatically set the scale.
-Mellobuck
05-31-2007 08:12 AM
Thanks for your reply.
I have found the problem. The 'HV Conductor Current I' variable needed to be connected to the middle FOR loop and not the most inner one. The resultant surface graphs were wrong because of this.
Thanks, however for taking the time to troubleshoot my problem.
Alex
05-31-2007 08:27 AM
Good Morning,
With some mentoring from the skilled LabVIEW Zealot that resides a few cubicles away, I have found how to access the property nodes on the 3D plot. Please find attached a VI that programmatically sets the scale of interest to 600-700. You can change the code to fit your needs.
Many, many more details can be found at :
http://forums.ni.com/ni/board/message?board.id=170&message.id=143663&requireLogin=False
( the VI should be in 8.0 this time. 🙂 )
Mello
05-31-2007 10:11 AM
For some reason I still have a problem with loading you VI. I get an error for cw3dgrph. I do however, understand the advice you are giving me.
Thanks for the link to the other post. It looks very useful. I will try and study it a bit later.
Anyway my VI is working and I have attached it.
Alex
