How can I run Labview with Streamline (from Dantec), without crashing?
Dear sirs,
I'm having problem working with LabView and Dantec Stream Line software.
My guess is that both are trying  to use the aquision board (6071E) at the same time causing the software to stop or crash.
Is there any way to work around on this?
Regards.
(3,433 Views)
You can use DAQmx Reset Device.vi to abort any task using that acquisition board. Check if it works.
Fernanda Silveira
AE
Brazil
(3,381 Views)
