How to solve the failure: "menu.cpp", line579
At start up, The error is issued. can't run it.
(3,933 Views)
Not sure what is going on but you may try:
1. Installing the latest LabVIEW patch.
2. Reinstalling LabVIEW being sure you completly get rid of all folders, registry entries, etc.. when you unistall.
One question to help us: What version of LabVIEW are you running?
(3,932 Views)
Thank you very much. I installed without deleting all folder at first. reinstalled also can't work. after it, I deleted all folder and software. it works. I am using LabVIEW 6.1
(3,932 Views)
I had problems changing video resolutions... when I saved at 1280 and
reopened at 1024....
(3,932 Views)
I just downloaded LabView 6.1 for Linux and encounter the same problem. Crashes right upon startup. I am running openSuSE 10.2 with fvwm2. Any ideas?
(3,704 Views)
