Help making a event counter for beer fermentation
Chilly
I ran the vi again and put the same numbers as you and got 568.28%abv! Maybe I screwed up my copy?
As for the .13 abv per 0.01 decrease in gravity, I got this from a program I use called Promash. So thats the correct math.
Im including my copy of the burp converter so we can get on the same page.
Message 51 of 83
(2,118 Views)
Chilly
Here is a link to the software http://www.promash.com/  If you use the % Alcohol Calculator and put the OG at 1.043 and FG at 1.044 you will get .13 abv. Ya know what!!! Im a idiot!! Im sorry every .13 abv= a 0.001 change on gravity!
Message 52 of 83
(2,119 Views)
Seems that you are using a fossil copy. There has been a mix between versions. Use the one attached, or reload the last version I sent you.
Chilly Charly    (aka CC)
Message 53 of 83
(2,119 Views)
I have downloaded the ProMash application. I can tell you that the alcohol calculation is just crap. People behind that have just loaded tables of alcohol density and forgot that the sugar to alcohol conversion is not a one to one transformation !
I hope that the rest of the program is better ! And that you didn't pay for it !  😉
Message 54 of 83
(2,117 Views)
Hey Chilly
I fooled with the new vi and it works better but the alcohol level is less than half of what it should be. I thought Promash was a good program. Ive always hit the gravitys and confirmed it with a Hydometer and refractometer.
The ratio between abv and gravity is used by the big breweys too. I dont know the details of that number though.
Anyway have a nice daySmiley Happy
Message 55 of 83
(2,106 Views)
Interesting thread...
abv changes gravity... That would explain why the floor slams on my face when I'm .13...
Smiley Very HappySmiley Very HappySmiley Very Happy
LabVIEW, C'est LabVIEW
Message 56 of 83
(2,098 Views)
I must apologize : the calculation of the alcohol content from the CO2 efflux was right, but the calculation of the SG was wrong !
The 0.13 figure that you use is probably not so bad (and even good :P). I'll come back with a better estimate.
Meanwhile, the Convert Burps vi has been corrected. Use it instead of the previous versions.
Message 57 of 83
(2,087 Views)
Thanks buddy!
Message 58 of 83
(2,085 Views)
Labview to produce BEER, it really is the coolest language avaliable.  I suggerst you call your production LabBrew (the G powered beer).  I would buy a case!
-Paul
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
Message 59 of 83
(2,120 Views)
Hi Trimixdiver,
It sounds like you have this working, so I may be late in entering this discusion. If you need some on-site support, let me know.
Ben
Library, PA
Message 60 of 83
(2,075 Views)
