convert a VI into a .exe
Hello, I'm an electronic trainee french engineer.
I have done an application with a main VI (what I launch to use my application) and 16 libraries. Is it possible to convert my labview application into a .exe ? I use Labview 7.0.
Thank you
labview 7.0
(3,680 Views)
This is possible, if you have the Application Builder included in your LV.
Using LV8.0
Don't be afraid to rate a good answer... 😉
(3,675 Views)
Close Labview to clear all vi's from memory.
Reopen Labview and chose new vi.
Under tools find application builder
NAme Target and loacation
Load source files
Add support files(if any)
Check VI settings
Application settings
Installer settings
Attached png shows application builder location.
chow xseadog
(3,669 Views)
After everything is ok
then press build
Hopefully you should have a functional application
save bld file so if you have to moduify code in 'sub vi's
then it is not necessary to reload full project. (vi locations etc)
chow
xseadog
(3,666 Views)
"Under tools find application builder "
I have not "application builder"...
labview 7.0
(3,653 Views)
The application builder only comes with the professional version of LV, and you don't seem to have it. You can buy it seperately from NI.
___________________
Try to take over the world!
(3,646 Views)
