07-13-2005 12:27 AM
Thanks Chilly
I didnt use the new version yet but I will soon. I have one question for you. Could you add some math so that every .13 in the abv equals 0.01 on the SG part of the vi? So I would enter the OG and it should take off 0.01 on the SG for every .13 of abv.
Thanks alot
Im including the current vi that Im using
07-13-2005 12:28 AM
Here is the vi
I forgot
07-13-2005 12:30 AM
Oh yea
here is a link to my fermenter camera inside the cooler, looking at what started this whole thread.
07-13-2005 02:08 PM
trimixdiver wrote:...I didnt use the new version yet but I will soon. I have one question for you. Could you add some math so that every .13 in the abv equals 0.01 on the SG part of the vi? So I would enter the OG and it should take off 0.01 on the SG for every .13 of abv.
07-14-2005 12:13 AM
Ok Chilly
Thanks, I ran it but the abv was way too high. Also the tank volume, do you mean the amount of beer in the tank or the actual tank?
Is there anything I can do for you? I feel like Im taking advanage of you.
07-14-2005 05:02 AM
07-14-2005 05:10 AM
07-14-2005 10:58 AM
Hello again
I am running the latest vi right now. The counts are perfect!! Thanks. Now the math is off. I did a vi that will do the math to get Alcohol by volume of the gas expelled. But having that info and not knowing labview enough yet, I need to get the OG input to count down 0.01 for every .13 abv. Yours is great and has alot of detail but I entered the volume in liters, 10 liters and the burp volume 2ml and after the second burp it shots to 12-24% abv! (I wish I could make beer that strong! Anyway you are the best.
Also do you like beer? If so I can recomend some nice farmhouse ales in France!! Also take a trip to Belgium! Get the Satan pale ale, it tastes sweet but at 8%abv, after 2-3 it will rock your world.
07-15-2005 10:49 PM
Chilly
I know Im pushing it...But, Is there a way to add a burps per hour chart? I tried but couldnt get the counts per hour portion. Also If you can do the .13abv will decrease the OG amount by 0.01.
So it would be a adjustable for the OG and a readout for the current gravity (.13abv=0.01) and a readout for how much longer (in days and hours) by inputing the final gravity.
I know Im pushing, but I just cant or dont have the labview brains yet.
Oh yea Happy Bastille Day (sorry for spelling) and a French stage in the tour.
07-16-2005 12:11 PM
Hi 3mix
I believe the burps/h chart would not be necessary if the "maths" were correct. And they should be, or will be soon !
I don't get the same results as yours : with a 2 ml burp volume, and a 10 l mash volume, the abv reaches 0.01 % after 200 burps. What's wrong ? Could you check the calculations by running directly the Convert Burps sub- vi ?
And I have some difficulties with the correspondance between abv and SG : 0.13 % abv is 1.3 ml alcohol per litre. 1.3 ml is 1.03 g alcohol/l, and correspond to the conversion of 2 g sugar/l. That can't correspond to a SG variation of 0.01 (about 10 g/l). What's wrong ?
