Grade Book Project
I have been trying to build a grade book which takes an array with a students name, exam1 exam2 final exam outputs an average  in both numeric and letter form. I also want it to sort the students from highest average. I have gotten the program to do all of this except one final thing. Once it sorts the students from highest to lowest grade based on average i also need it to display number rank such as 1, 2, 3, 4 next to the student. Example Name Score  Grade  Rank
               Sam      90       A        1
               Tim       88       B         2       etc.
Any help would be great i have tried so many things but am having trouble.
(3,549 Views)
Care to tell us what the problem is? Besides the slobby wiring...
(3,511 Views)
You just need to add a # field to your cluster and in the 2nd loop, set it to N-i.
/Y
Qestit Systems
Certified-LabVIEW-Developer
(3,508 Views)
/Y
Ah, that was the problem... Monday morning...
Alternatively, in the 3rd loop set it to i+1. Might be a bit more intuitive.
In >LV17 there is a vim to sort 2D arrays on a specific column. Doesn't solve this problem, but makes more sense to use what's available. It opens doors to sorting on a given column,
(3,502 Views)
wiebe@CARYA wrote:
/Y
My bad, the 3rd loop! It should still be N-i, since it's reversed afterwards. 😉
/Y
Qestit Systems
(3,499 Views)
@Yamaeda wrote:
wiebe@CARYA wrote:
/Y
/Y
Right again, of course (still Monday).
I'd do the sort, then reverse, then build the new array. Makes more sense to me... Then you can use i+1.
Anyway, looks like the original question has been answered? OP still listening?
(3,489 Views)
Yes thank you all for your help.
(3,457 Views)
