Finding consecutive repeating numbers in binary array (or boolean)
@simmertime wrote:
The input is a digital waveform of size 496 (1D).
A digital waveform can have several signals. Can you give a more specific example? Are you using the tools from the digital conversion palette? (would give a 2D boolean array or a numeric array with multiple bits/value).
My code above can easily do exactly what you need.
  • output the number of TRUEs if there is exactly one consecutive stretch of TRUEs (Count: 1..N)
  • output 0 if no TRUE exists. (same as "none found")
  • output -1 of more than one group of TRUEs exist. (same as "error")
Message 11 of 18
(2,396 Views)
@simmertime wrote:
The input is a digital waveform of size 496 (1D). I convert it to a boolean array(T/F) and binary array(0/1) for other reasons. From the input I want to count how many ones are sandwiched between zeros, but if there are more than 1 sandwich I want to have a string indicator that there is an error. If there are no 1's found, I would like the string indicator to say none found.
000111111000 Count= 6
0001110000111100 "Error"
000000000000 "None found"
There are a few more cases to define.
1111100000 or 0000011111 no leading / trailing 0 1s length indeterminate?
0000111111100111 or 1100001111110000 one sandwich and an incomplete pattern?
"Should be" isn't "Is" -Jay
Message 12 of 18
(2,383 Views)
If a 1 is at the start or the end that is an error. I would call it "incomplete data" regardless if it is 1110000 or 11000111000 (doesn't matter if it is the only chunk)
Message 13 of 18
(2,364 Views)
Can you include this vi or list the components used? I'm having a hard time identifying them.
Message 14 of 18
(2,353 Views)
This is a long thread. Are you replying to any particular message? In that case you should quote some of it (as I just did right here above) so we know what you are referring to.
Message 15 of 18
(2,342 Views)
Accepted by simmertime
Here's my VI from the picture above. You might have trouble finding the "search array" because it has changed to a malleable tool (different color, more functionality)  in recent versions.
Message 16 of 18
(2,338 Views)
To wrap this up, here's how it can be simplified if we only want the simple nonzero count and -1 otherwise.
(You can add the "OR Sum=0" back if you want to output zero if the array is all FALSE)
- Output the count of TRUEs if there is exactly one consecutive stretch flanked by FALSE
- Output -1 if
     - There is more than one stretch of TRUEs
     - All elements are FALSE
     - The input starts or ends with a TRUE
Message 17 of 18
(2,324 Views)
Hi altenbach,
I liked that the output could be -1 (invalid), 0 (no 1's found), or the sum. I added a few things to search if 1 is found in the beginning and the end and output an error (just an index array for the first and last, then OR those together). Thanks for your help!
Message 18 of 18
(2,316 Views)
