07-07-2007 04:26 PM
Hi
I have a file on a server called test.exe,say. The directory structure on the server is as follows:
-test
-dir1
-dir2
I am having problems in accessing the data from a web browser. I think the main problem is what paths do I use to access the data from test.exe in a web brower?
Note: I am using FTP.
07-07-2007 06:06 PM - edited 07-07-2007 06:06 PM
You seem to be using a web browser for ftp, so I don't quite understand what all this has to do with LabVIEW. 😉
Using internet explorer you can access any file via ftp using simple paths, e.g.:
ftp://myserver.mydomain.com/test/dir1/test1.dat
If the server is passworded, you can use:
ftp://username:password@myserver.mydomain.com/test/dir1/test1.dat
What error messages do you get?
Message Edited by altenbach on 07-07-2007 04:07 PM
07-08-2007 03:12 AM
Hi
Thanks for that.
Here is the error that I get.
07-08-2007 03:22 AM
07-08-2007 03:24 AM
Sorry |
07-08-2007 03:26 AM
07-08-2007 03:41 AM
07-08-2007 03:58 AM - edited 07-08-2007 03:58 AM
| Here is the attachment. |
try again !!!!!!!1
Message Edited by tudsy on 07-08-2007 04:00 AM
07-08-2007 04:14 AM
try again !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! |
07-08-2007 11:52 AM - edited 07-08-2007 11:52 AM
Seems you have a couple of problems:
Here's the commandline I used. I entered username and password when it propted me
ftp://members.iinet.net.au/ECOTUD/MarioSmith/MarioSmith.bmp
Message Edited by altenbach on 07-08-2007 09:53 AM
