labsql step-by-step
(sorry my english), I'm brazilian and I've already read all questions e answers but I don't get use LabSQL with my Access database file. I'd like, if possible, one explanation step-by-step how can I do to only open one *.mdb file. The treatment after openning the file I think is not difficult. My great problem is open de file. I think my error can to be in DNS creation or call it into VI.
My OS -  Win XP
LabView - 7.1
Thanks.
(3,521 Views)
Luiz;
To connect to an Access database is very easy. All that is required is the right connection string. Attached is a package of documents I creaed a while back that explains the database access process. It also demonstrates how to connect to a *.mdb file. Note that it doesn't use LabSQL but if you look inside the LabSQL VIs you will see the ActiveX nodes that are in the code in the archive.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,512 Views)
Thanks Mike, I'll try this example!
(3,447 Views)
