Example of transparent splitter bars.
I can't attach files in my comments on labview ideas exchange (NI please fix that), so instead I'm making this post to link to from idea exchange.  This shows how to do a transparent splitter bar in a subpanel.
Message 1 of 8
(5,537 Views)
Post a link here to your Idea Exchange post.
aputman
Message 2 of 8
(5,518 Views)
That's funny. If the subpanel is not set to be transparent, the splitter takes the main VI's background color, not the VI in the subpanel's background color.
That might be what is required, but technically, you still don't get a splitter that shows the VI's background color because it's transparent. I'd expect a transparent splitter to show through the color of it's pane, not the color of the pane of it's parent.
Message 3 of 8
(5,513 Views)
Good point. Here it is.
Message 4 of 8
(5,510 Views)
Message 5 of 8
(5,508 Views)
I have to mark something as the solution so I'm making this comment 🙂
Message 6 of 8
(5,420 Views)
You don't have to mark any message as a solution.  You get an e-mail to remind you to check back and mark something in case you forget.  But if there is no actual solution, you should not mark a random message as the solution.
Message 7 of 8
(5,410 Views)
I think the first post gives the answer, since it's an example that shows something. You'r not really asking anything. I'd prefer you mark the OP as solution, not a random comment.
Message 8 of 8
(5,389 Views)
