Example for Defer Panel Update
Hey guys,
could someone post an example of how to use the 'Defer Panel Update' property. I am having Problems to understand when and how it is used. The LV help is not very informative. Would be great to have an example vi.
Thanks!
Message 1 of 13
(15,997 Views)
Here you are, I hope it useful
Regards, Jens
Kudos are welcome...
Message 2 of 13
(15,967 Views)
thanks! Could you explain, what is exactly the advantage if i use it when changing for example the color of a graph. What happens differently in the two cases?
Message 3 of 13
(15,958 Views)
If you do a lot of changes (eg. change several settings of several plots) it will take considerably longer without defer panel update, because each (!) setting of a property (even if you combine several properties in one node) will lead to an update of the front panel.
Regards, Jens
Message 4 of 13
(15,951 Views)
Defer Panel Updates makes LV not synchronise UI actions with the screen updates.
Try inserting 200 (or 2000) items to a tree control. It will take forever. Turn Defer Panel Updates on, and it's done in a flash (well, much faster).
Even updating values with a property node makes each "write" synchronise with the screen. So updating a control with a property node 6000 times might take a relative long time (notice the flashing). Try Defer Panel Updates on and off, and see the difference.
Message 5 of 13
(15,950 Views)
http://zone.ni.com/reference/en-XX/help/371361H-01/lvprop/pnl_defer_pnl_updts/
If Tetris has taught me anything, it's errors pile up and accomplishments disappear.
Message 6 of 13
(15,941 Views)
Could someone post two simple vis where you see the difference (with and without deferpanelupdate) ?
Message 7 of 13
(15,909 Views)
Accepted by volfi
You really need an example after all the input you got?
OK, here's a very simple one.
Regards, Jens
Message 8 of 13
(15,898 Views)
Regards, Jens
Kudo for your patience. (But he did ask for two VI's...)
Message 9 of 13
(15,891 Views)
Well, he can start it two times with two different settings for the Boolean in the front panel. Smiley Happy
Message 10 of 13
(15,874 Views)
