Error 20023 "The following conditions must be met: 0 < f_low <= f_high <= fs/2."
Thanks alot ive fixed it. now no error. Earlier you said it was cluttered. What vi's can i replace?
Message 21 of 23
(1,144 Views)
  • A low-pass followed by a high-pass (or vice versa) can be replaced by a single bandpass filter.
  • Eliminate the local variable
  • Use index array to get the number of peaks from the array. (>ToDBL>ToDDT>FromDDT> is just plain silly!)
Better: As I said, scrap all your code and go with my earlier ptbypt suggestion.
Message 22 of 23
(1,141 Views)
I changed to ptbypt earlier so i will change to what you just said thanks once again.
Message 23 of 23
(1,138 Views)
