Don't allow mouse wheel to scroll the vertical scrollbar after reaching the last element in array control
Hi
I've an array control with some number of elements. When I scroll on array control, the vertical scroll bar keep on going and displaying the empty elements in the array. Is there any property available through which I can control the movement of scroll bar?
Attached image for reference.
Thanks in advance!
Message 1 of 12
(5,521 Views)
I suspect you will need to use a "Mouse scroll" event.
Inside the event you can get the control reference then use some property nodes from there.
You could take the array size and subtract the NumRows to get the highest allowable top index.
If the index you have attempted to scroll to is greater than the highest allowable, set it back to the highest allowable with another property node.
0xDEAD
Message 2 of 12
(5,505 Views)
Accepted by PadmanabanJ
If your LV version supports the Mouse Wheel event, you can hook this event and correct the IndexVals property
Paolo
Message 3 of 12
(5,503 Views)
I Was thinking along same lines.
Message 4 of 12
(5,494 Views)
But I was a little bit lazier Smiley Happy
Paolo
Message 5 of 12
(5,481 Views)
I doubt you can properly catch\intervene that event. You'll always see flickering\artifacts.
I usually end up with a separate scrollbar and array. The separate scrollbar can be programmed with any max value and page length... A bit more work then desirable, but AFAIK the only way to do it right.
Message 6 of 12
(5,480 Views)
Yes its a shame there is no filter event.
Message 7 of 12
(5,467 Views)
How about adding a pop-up ("at end of array stop scrolling!") then set the key focus to someplace else.
Ben
Message 8 of 12
(5,459 Views)
Thanks everyone.. This solution meets my requirement.
Thanks for your concern for flickering effect but it is not a big deal in my case 🙂
Message 9 of 12
(5,444 Views)
Interestingly, this doesn't work for array indicators.
When I had a look into the problem it seems that its a bug as discussed here:
https://forums.ni.com/t5/LabVIEW/mouse-scroll-array-indicators-bug-LAVA-x-post/td-p/3730630
Thought I would link it here in case anyone searches this in the future.
0xDEAD
Message 10 of 12
(5,432 Views)
